1 - 1 of 1 Posts
My spedo dosent work I have 2.7l with a 5spd w/o abs and my question is where does the internment ground come from that goes to top speed sensor on the transmission because right when you manually spin it does nothing but if you spin while giving a brief ground to the signal side the cluster comes to alive going up steady and the gears on the sensor are good, wheel speed sensor is good, fuses good
1 - 1 of 1 Posts
