1 - 2 of 2 Posts
Hey so i have an 05 tib gt v6 5speed. So the issue is the headlights flash once the keys in the on postion and the only way to get it to stop is to either turn the headlights on or turn the headlight stalk to the high beams, high beams still only turn on once the headlights are on, also at the same time the reverse lights only work when the headlights switch is in the off postion. Also, the fuse is currently out so they shouldnt be working at all and it the fuse is put in it simply pops once the cars on. I believe its a faulty wiring harness but i just want to make sure before i try looking for one and rip apart the intake any help would be appreciated. Thank you.
I have an 03, which has fuse positions for high and low beam headlights separately. Are you running stock bulbs, or HIDS? Can u try stock if not already? I know HID kits draw a lot of power at start up. If HID, check ballast.
Maybe disconnect only low or high or only left or right to isolate the problem?
And as always, when did the problem start?
And what changed???
1 - 2 of 2 Posts
