Hi y'all, I wasn't sure if I should have put this in general or GK Performance section, so apologies if this is out of place. In my 2006 2.7 SE, the transmission won't shift into 6th gear. It feels like there's just no sixth gear, though there is a reverse lockout pull thingy on the shifter so I'm nearly certain it is a 6 speed.
Anyway, I took the shift cables off and shifted the transmission directly from the engine bay to eliminate the shifter and cable mechanisms from the equation. Sure enough, shifted into every gear (including reverse) except 6th again. It feels like there's just no slot for it. I searched on this forum some and found a few posts from about a decade ago, some were saying shift forks could be bad, and others said that the fork for 5th and 6th is the same. Since it shifts into 5th fine, its likely not that. Unless their data was wrong. I also came across someone who said that something to do with a worn 5th gear will cause some metal to buildup somewhere, so that the 6th gear sleeve can't be engaged? Or something like that. I'm not sure exactly what he meant, lol.
Has anyone successfully dealt with this issue? I really don't want to have to pull and/or overhaul a transmission. From what I've heard, a multiton press is required. It wouldn't surprise me if the trans is a bit worn; I've grinded 3rd and 5th a few times despite the clutch being flat on the floor. Should I try to put it in 6th with the engine on and clutch partly engaged? Maybe to force the burr on 6th in the trans to come apart? Or something? Any insight is much appreciated
