The drains are stuck into the corners that may be covered by dust/dirt/pollen, etc. I always pour water (a cup or so) down the drains after snaking with string trimmer plastic to verify they work and to flush out any remaining crud.Thanks for the details. So is the only way to get to those drain tubes was to remove the headliner? I was thinking you could snake them (with string trimmer line) from the outside of the car with the sunroof open?
I opened my sunroof one day and took a quick look for the drain holes, but didn't see them. Granted, it was a quick look, but no joy.
No pictures, it was my ex's car and she moved over a year ago. I have no acces to a Tib easily, but yes, I snake from the top 95% of the time on any brand.Thanks again guys.
So Charlie, do you have any pics of the holes from the top? Were you able to snake all four from the top-side without pulling the headliner?
I've had seam sealer leaks on a Civic and a Highlander, and now (probably?) the Tib.The only vehicles I've ever had seam sealer issues with were my to Toyota MR2s.
Use electrical tape to seal the seams of the sunroof completely. Leave it like that until you see if it fixes the issue. Should be able to tell with a hose pretty quickly. Worked for me to diagnose an air leak and the tape peels off clean. Good LuckWife has a 2008 SE model. Been dealing with a leak. Passenger rear floor had been getting soaked in heavy rain. I pulled the headliner and found the rear passenger side sunroof drain hose was completely off. I blew out all 4 drain hoses then reconnected and zip tied back in place. Had a lil white mold looking stuf on the bottom side of the headliner so took care of that and reinstalled. Had rain this morning and passenger rear floor is wet again. Any thoughts of where it is getting in. I have already replaced the hatch weather stripping as it was also leaking if heavy wind with hard rain. Not sure where the water can be coming from.
