Yeah the Kenwood amp is freakin sick I keep the sub level on the HU on -6 and teh gain on the amp is completely down and my freakin car still shakes. Insane is all I can say. Thanks again Cycon82 for that wiring diagram got them setup exactly like you said and it sounds amazing. Hopefully we can get the sucker metered one day and see what these alpines are capable of. I just got my multimeter to tune the input level sensitivity and the amp altogether so I need to get than done soon to. Now I just need to dynamat the damn car :3_frusty:cycon82 said:you are going to need a d class mono block amp with a 600-700 watt 2 ohm rating.
run each sub in series from one coil to the other, then run the two subs together in parallel to get you to a 2 ohm load.
amp options that would work for you:
Infinity Reference 611a - probably the best power option
Alpine MRP-M650 - dead on power rating (IMO may be a bit under powered)
Kenwood KAC-9102D - awesome amp and would work, but you may need to bring your voulme level down or you will over power the subs. - ohyaa69 would know about these amps and the sweetness that they are.
PM me if you need wiring diagrams or extra help
Don't forget the pink noise CD, you have to do that at a certain hertz level!ohyaa69 said:Yeah the Kenwood amp is freakin sick I keep the sub level on the HU on -6 and teh gain on the amp is completely down and my freakin car still shakes. Insane is all I can say. Thanks again Cycon82 for that wiring diagram got them setup exactly like you said and it sounds amazing. Hopefully we can get the sucker metered one day and see what these alpines are capable of. I just got my multimeter to tune the input level sensitivity and the amp altogether so I need to get than done soon to. Now I just need to dynamat the damn car :3_frusty:
I use to have one written down that you could order off the web. Call JL audio and ask for the tech department and then tell that guy you are trying to do what you are trying to do, and you need to know what CD they recommend, that is how I got it, just have to figure out which manual I wrote it in! L8Rohyaa69 said:Yeah I was gonna ask you guys that, where can I get the test cd or is there just a track I can download and burn. Oh sorry for the hi-jack
