1 - 2 of 2 Posts
Would the use of wheelspacers/hubcentric rings allow me to use these rims without worry of offset and looking retarded having the wheel deep in the fender?
Thanks
Yes. You could probably run a 15mm wheel spacer and it would look perfect. Make sure that the back of the wheel has relief spaces for the spacers and wheel studs. You could also get spacers and extended studs, but that is a lot of work and labor cost.
You may even be able to run only a 5 mm spacer and not have to go through all the drama of a thicker one. You could probably get 4 5mm spacers off of ebay for $50 shipped.
1 - 2 of 2 Posts
