OK guys I'm stuck... I've replaced basically everything from the pedal up to the flywheel. The master cylinder, the slave cylinder, the tob, the pressure plate and the clutch disk. I bled the system good no air. When I try to press the clutch pedal down its like I'm standing on a rock, totally solid, idk but it seems like the fork that goes into the bell is stuck forward and the slave is fully extended. I cant move the fork at all. Could something have gotten messed up while I was putting the tranny back in the car?
I've searched high and low, scrounged the internet for all the info I can find and it wasn't anything helpful. Please any info you have is much appreciated I'd hate to see my project go to someone else over this lol.
http://www.newtiburon.com/forums/transmissions/190374-__-how-do-diy-clutch-job-tiburon-s-pull-type-clutch-system-__.html
Adjust your clutch push rod. Between master cylinder and pedal
Please don't bump most threads over a month old per forum rules.
This issue is a year and a half ago, likely resolved already.
