1 - 18 of 18 Posts
I am out here putting the 2.0l and 5 speed trans from my tiburon in my brothers veloster. I have the entire harness pulled. I have the engine running, what I am wondering is what can I eliminate from the harness. I don't have access to wiring diagram so any info would be awesome. Thank you all. I can take more detailed pics of the harness if it helps.
Motor vehicle Automotive tire Purple Automotive design Rim
Automotive tire Motor vehicle Hood Vehicle Automotive design
2006 Hyundai Tiburon SE
That sounds like an interesting project. Are you keeping the OEM ECM or going standalone with it?
There isn't much you can delete from the OEM 2.0 harness without receiving a CEL. But you can delete your EVAP and downstream O2 sensors from the harness without affecting runability.
I can get you a pinout for the SIMK43 ECM harness later when I get to a computer. Anything specific you are looking for?
Id like to stay oem for now. I have an safc2 on the oem ecu for when I had the blower and then turbo which wasn't ideal for the turbo. But to get going I am throwing the engine in stock to begin. I feel dumb but idk how to say it. I want to remove the extra body stuff without affecting the engine section of the harness. Guessing I am overthinking it. I just get nervous hacking stuff up without any wiring diagrams to correct myself if and when it goes south. Thanks for looking.
Cool 😎!! Thanks man! I got fused power and a ground run to the ecu I had those labeled from the safc2. Completely unhooked bcm. Jumped the starter and got it running. Shop manual has wiring diagrams and pinouts? I am just tracing wires at this point. Been just running from fuse box cutting out the stuff I know isn't needed.
Indirectly it shows you ECM pinouts in the schematic diagrams but it's broken up into different systems. If you look in the Electrical Troubleshooting .zip file under the SD.pdf file you will see grayed out blocks labeled "ECM" where it will show you pin numbers. Double check the manuals to ensure it applies to your donor vehicle 2004+. Your SIMK43 ECM differs greatly from the earlier SIMK41 variant from 2002-2003.
For example the MFI CONTROL SYSTEM shows the ECM pin numbers it uses specifically in diagrams like this:
Rectangle Slope Line Font Schematic
Discussion Starter · #10 ·
Shes seen a couple setups... Super charger then turbo a few years later once the intake manifold on the supercharger started developing cracks. Engine management definitely held me back with the turbo. Absolutely going stand alone once this is all sorted. Any standalone recommendations. And once again thank you all for the help!
Haltech Elite 1000+ or FuelTech
But it all comes down to a person who can tune.
I would personally convert to an early SIMK41 OEM ECM that supports a MAP sensor and tune on that. The harness plug pinout to the ECM is completely different but you can repin it and use the MAP harness in place of the MAF harness. There isn't a lot of information out there for tuning the OEM ECM but I have had some success reading/writing a relocated and removable EEPROM. I have also located a few maps on the SIMK41 that are useful for tuning. I can give you some of my information on it but it's still a very slow work in progress.
The general consensus on standalones is to call your local tuner and ask what they recommend. They will have their own preferred setup they know best. Doesn't help if you buy a lesser expensive DIY/opensource Megasquirt or Speeduino just to find out they only support Haltech or AEM.
I’m having issues trying to pull up the ECM SIMK 43 Pin out for the 07 auto I4….
I dug up an old text file in my archives that appears to be a BETA II ECM harness for the engine management side. Unfortunately I did not find the automatic transmission control side of the SIMK43 pinout. I'll check Mitchell on Demand to see if I can find something later in the weekend and let you know.
1
ECM ground
Chassis ground
2
Power stage ground
Chassis ground
3
Direct battery voltage supply
Battery
4
Ignition coil output 1,4
Ignition Coil #1, 4
5
Ignition coil output 2,3
Ignition Coil #2, 3
6
CAN LOW
Other control modules (TCM, ABS, etc.)
7
CAN HIGH
8
HO2S Heater (B1/S1)
HO2S (B1/S1)
9
HO2S Heater (B1/S2)
HO2S (B1/S2)
10
Knock Sensor Input
Knock Sensor
11
CVVT Oil Control Valve output
12
Not connected
13
Not connected
14
Battery Voltage Supply after Main Relay
Main Relay
15
Not connected
16
Not connected
17
Wheel Speed Sensor (-)
Wheel Speed Sensor (WSS)
18
Wheel Speed Sensor (+)
Without ABS
19
Not connected
20
Not connected
21
Main Relay
22
Battery Voltage Supply after Ignition Key
Ignition Key
23
Injector output (cyl. 4)
Injector (cyl. 4)
24
Injector output (cyl. 1)
Injector (cyl. 1)
25
Spare Sensor supply
Sensors
26
Purge Control Solenoid Valve (PCSV) PWM output
27
Crankshaft Position Sensor ground
28
Not connected
29
Crankshaft Position Sensor input
30
Camshaft Position Sensor ground
31
Engine Coolant Temperature Sensor input
32
Throttle Position Sensor input
33
Fuel Tank Pressure Sensor Signal input
Fuel Tank Pressrue Sensor (FTPS)
34
Fuel Tank Pressure Sensor Signal ground
35
Not connected
36
Not connected
37
HO2S (B1/S2) ground
HO2S (B1/S2)
38
Throttle Position Sensor ground
39
Signal input Wheel Speed Sensor input
ABS Control Module
With ABS
40
Not connected
41
Not connected
42
HO2S (B1/S2) input
HO2S (B1/S2)
43
HO2S (B1/S1) input
HO2S (B1/S1)
44
Fuel Tank Pressure Sensor Supply
Fuel Tank Pressure Sensor (FTPS)
45
Throttle Position Sensor supply
46
Spare Sensor supply 2
Sensors
47
Immobilizer Data Line
Immobilizer
With Immobilizer
48
Sensor ground
MAPS, IATS
49
Not connected
50
Air Conditioner Compressor Switch input
Triple Switch
51
Air Conditioner Pressure switch input
Triple Switch
52
Oil Temperature Sensor input
53
Not connected
54
Knock Sensor ground
Knock Sensor
55
Ignition shield ground
Ignition Coil
56
Intake Air Temperature Sensor input
MAFS, IATS
57
Not connected
58
Air Conditioner Request Switch input
59
HO2S (B1/S1) ground
HO2S (B1/S1)
60
Mass Air Flow Sensor signal input
MAFS
61
Injector output (cyl.3)
Injector (cyl.3)
62
Injector output (cyl.2)
Injector (cyl.2)
63
Not connected
64
Cooling Fan Relay - High control output
Cooling Fan Relay
65
Cooling Fan Relay - Low control output
Cooling Fan Relay
66
Engine Speed signal output
Tachometer
67
Main Relay control output
Main Relay
68
Air Conditioner Compressor Relay control output
69
Electric Fuel Pump Relay control output
70
Malfunction Indicating Lamp (MIL) output
71
Immobilizer ground
Immobilizer
With Immobilizer
72
Camshaft Position Sensor input
73
Engine Coolant Temperature Sensor ground
74
Throttle Position PWM output
75
Fuel Consumption signal output
Trip Computer
76
Oil Temperature Sensor ground
77
Diagnostic Data Line (k-Line)
Data Link Conector (DLC)
78
Idle Speed Control Actuator PWM output 2 (CLOSE)
79
Canister Close Valve Control output
80
Idle Speed Control Actuator PWM output 1 (OPEN)
81
Immobilizer Lamp output
Immobilizer
With Immobilizer
As far as computers go stay away from AEM. They suck and their customer service sucks and every product I've ever had from them works for a year and then started to have glitches.
Would you mind listing the products and model numbers you've had issues with?
Here is your PCM/TCM pinout for the transmission controls (Colors may differ but the pint numbers are correct):
Font Parallel Rectangle Number Pattern
1 - 18 of 18 Posts
