I AM NOT SELLING THIS CAR! PLEASE CONTACT OWNER IN THE CL AD.
A client of mine is selling his racecar. Only downside is it's got no title so it's only good for a racecar or parts car. It's got one of my programmable ECUs with the parts bin and I'll support the new owner any way I can with remote tune help.
The ad:
Wheel Car Tire Vehicle Sky
Vehicle Car Motor vehicle Hood Steering part
Overview
2003 Hyundai Tiburon fully built endurance car. Group of 4 engineer friends bought/built/maintained the car from 2019-2022. While it was a budget build there were not any corners cut. Unfortunately after our last race with the car going to a new home/primary care provider (3/4 of the team accepted new jobs in other cities), the engine was left with only water in the block over winter and cracked. We’re selling the car as is, knowing it will likely need a new engine. This car ran and drove supremely up until the end of 2021, but with the team having moved to new cities maintaining the car is increasingly difficult. We feel it’d be better looked after in someone else's hands and have decided to part ways with the car.
Car is located in Athens GA
Pros:- “ready to race”
Full SCCA/NASA style roll cage professionally built & installed
Car is fully stripped (sound deadening removed, doors trimmed, etc.)
Suspension & driveline upgraded (see mod list below)
SFI/FIA rated race seat & harness
Safety electronics wired to SCCA/NASA standard
Fire suppression system
NACA cooling ducts for driver
Plexi front and rear glass
Cons
Obviously the engine is the big one here
Minor body damage to left rear quarter & left door (rubbin’ is racin’)
Performance Items
K-Sport Coilovers 3-way adjustable
AEM Intake
Clutch Masters Clutch (brand new)
Clutch Masters Lightweight Flywheel w/new friction face insert
Mishimoto Aluminum Radiator
Mishimoto Oil cooler
OEM front big brake kit (2005 Hyundai XG350 front calipers, pads, & rotors) good used rotors
Hawk endurance race pads ½ used
NGK spark plugs(recent)
Braided metal brake lines front
Comes with Chip Tunes (Hammargren for support, will provide contact info)
General Maintenance Items (OEM unless otherwise mentioned)
Good used tie rod ends (replaced since purchase of car)
Front wheel bearings (used for 2 races)
Drive shafts (both LH&RH, used for 1 race)
Sway bar end links
Rear Poly sway bar bushings
Power steering lines
Fuel pump & filter
Cam position sensor
Crank position sensor
Knock sensors (both)
Recent timing belt & tensioner
Crank pulley
Tensioner pulley
Idler pulley
Clutch slave cylinder
Lifters
Clutch fork
Racing Items
MOMO Race Seat -
Seat slider kit -
NRG quick release wheel hub -
MOMO race steering wheel -
Racequip 5pt Harness -
Rear quarter window NACA cooling ducts
Mishimoto Oil Cooler -
Fire Suppression System -
Electrical Disconnect/Kill switch
Battery relocated to rear of car
6 point cage with door bars
Driver window net
Lexan front and rear glass
Set of 12 OEM wheel (4 on the car & 8 spares)
Oil Pressure, Oil Temperature, & Air/Fuel Ratio Gauges
Tires Maxxis Victra VR1 in 225/45/R17 - 2 gently used, 4 scrubbed, 6 dead
