1 - 5 of 5 Posts
I've got a 2003 6 speed gt that won't start. I shut it off to get gas and had to pop start it. Everything turns on and the battery is brand new, but it just won't start. Any ideas??
give us more symptoms, does it try to start, can you hear the fuel pump, is the clutch switch being reached and pressed, .. etc
Super Moderator
So.....it won't crank?
Looks like a USDM car, so no immobilizer.
When you try to crank, do you hear a click from the starter?
Can you measure battery voltage when trying to crank? It should stay up in the 9 volt range.
1 - 5 of 5 Posts
