1 - 3 of 3 Posts
does anyone know if i can take my 5sp outta my 2003 tiburon and put it in a 2005 that has a 4speed tranny..will they interchange
1: why not swap the 05 front bumper and headlights and taillights onto your 03?
2: you need to swap the ECU, Transmission, Shifter assembly, Slave and master cylinders, Clutch pedal, Clutch switch, transmisison mounts, maybe the left and right axles.
3: why not put the 05 engine into your 03 instead? not that there's that much of a difference except for age and mileage
I assume your "4 speed tranny" is an automatic? That would be a detail that you should probably include.
1 - 3 of 3 Posts
