1 - 3 of 3 Posts
On my 04 I4, When shifting the car into second gear. The check engine light is popping the fuse. The car shuts off and just coast till I hit the brake. Everyting else works in it, but I do here a low pop coming through the subs. I don't know what is causing the fuse to blow. Have anyone on here have that issue?
Any electrical work (including stereo) just before this started happening?
My guess, something is failing/shorting which pops the CEL and the fuse.
Which fuse?
What CEL?
CEL light shouldn't pop a fuse....it's just a small bulb...
Stero has been installed for years. The fuse that is popping is the check engine light at 10 amp. I'm going to disconnect the system and see what happens.
1 - 3 of 3 Posts
