Does anyone know what part on the back of a 2006 BCM communicates with the keyfob? I replaced my BCM with a used one annd all works fine except my FOB will not open the doors even after I reprogrammed the FOB. Is there a component on the back of the BCM that communicates with the FOB that can be replaced with one from original BCM to get the FOB to unlock the doors?
2006 Hyundai Tiburon SE
When you say you reprogrammed your keyfob did you take it to a dealer for programming? Or did you do the key on trick where you press lock/unlock at the same time to "resync" the keyfob? The resync only works if the BCM and keyfob are programmed to match. If you installed a different BCM you will have to reprogram your keyfobs and/or your BCM.
The keyfob communication comes from the BCM directly. There is a little antenna built into the BCM mainboard indicating that it is integrated with the BCM.
Passive circuit component Circuit component Hardware programmer Microcontroller Computer hardware
I just did the press lock / unlock trick. I was wondering if one of the removable components that jack into the back cover communicates with the fob via the antenna. If so, if I replaced it with my original component that was programmed to my fob, then I would not have to have the dealer do it. Do you know if one of the components on the back communicates with the fob? I only know that one is the chime, but I don't know what the others do. Thank you for your advice. I really appreciate your time to respond.
The FOB communication is built into the BCM as indicated by the built in antenna. There isn't a separate device attached to the BCM.
If the BCM changes then so does the programming requiring a dealer or locksmith to reprogram it. The lock/unlock trick will not work if the BCM is changed out.
