Hello Tiburon Forum
I recently assembled my Tiburon rebuilt 2.0L motor
I had the timing camshaft sprockets off (Its a single CVVT) because of this I received the code #P0011 upon resetting the cam chain (11-tooth spaces from intake to exhaust cams) that code disappeared however now Im getting a code
Crankshaft position sensor code #P0016
So I had another Crankshaft PS and swapped it out and now Im still get the same #P0016 code CPS
I rechecked the top timing cam sprocket marks dead on {new timing belt} and then rechecked the bottom crankshaft sprocket is dead on with the mark on the oil pump aligned
Im stumped? not sure what to do next? order a new OEM Crankshaft PS? or?
Thank you for any helpful feedback and wisdom
Sincerely
mike
Sincerely
mike
