I don't know for a fact, but assuming all else equal that tire will be 15mm closer to the wheelwell. People have put on 25mm spacers on stock 215 tires without rub so based on that I would think they will fit.
But now I must ask: why would you? 245s are way too wide if your car is otherwise stock; will create more rolling resistance than its worth. It's even worse if your rear tire is now wider than your front tire as you will then likely induce more understeer on an understeer-prone car. Put the 245s on the front if you can is my suggestion.
245 is pushing it, but it may be ok. I have 15 mm H&R spacers on the rear and while they don’t cause sidewall rub on the stock 215/45 Eagles, they do rub on my 225/45 Potenza RE070 summer wheels which are 17x7.5. Just enough to cut into the writing when cornering or hitting a large bump. So there’s your limit. 245s would likely work without spacers and stock offset.
Related Threads
Hyundai Tiburon Forums
3.2M posts
57.7K members
Since 2004
