1 - 11 of 11 Posts
hey, so rumor is an 05 sante fe with the 3.5L engine has 290 cc injectors... aparently a plug and play set up. now im runnin an 03 tib (v6 of course) and i was curious to know if i just slap in the 290s if it'll improve performance or will it just bog out (drowning the spark) at higher rpms/loads... if it drowns it out then i assume get an A/F piggyback?.... and having asked that... wouldnt i have to increase airflow before injectors? aparently our tibs starve for air in the higher rpm range...help haha.
Mod list : CAI
Headers to test pipe to stock resonator to side outlet straight pipe exhaust
n/a ECU reflash from NGM would qualify also...
Read Only
Yeah even at 210ish whp, the stock injectors are still able to handle the power effectively. I think when you get in that range you should worry about replacing injectors, as you are probbaly maxing out their duty cycle.
Headers next
Green are the same as stock v6 injectors. There are also white ones, but I dunno what cc those are.
1 - 11 of 11 Posts
