1 - 5 of 5 Posts
my gear shifting thingy is wobbling a lot and its annoying to shift gears
i need to change it
where can i get a new one? i cant find them anywhere
& is there an aftermarket one made from a different material? like metal or something i cant find one anywhere
Wood Gas Metal Fashion accessory Machine
Aircraft Vehicle Airplane Helicopter Wood
No there's no aftermarket replacement for that whole assembly. It doesn't appear broken, but those rubber bushings tend to have a lot of play in them. You can replace them with solid ones or just a stack of washers. This will probably solve your problem.
You can replace the whole assembly, I was just saying there's no aftermarket option.
If you have a local dealer check with them, at this point you may need to find a Korean supplier for that part though. I've dealt with Partsmotors.com before, they have been good to work with and are in Korea sourcing parts from dealers there. Their site is much easier to search by part number though so you might want to track that down first if it's not stamped on it somewhere.
1 - 5 of 5 Posts
