ok so ive got an 03 elantra (map based with narrowband o2 sensors) and ive got the fic wired in properly (yes i checked the wiring 3x) it ran JUST fine with everything zeroed out and a stock fuel system. I recently just installed the 1k ohm resistor into the o2 signal wire and then tapped 021+ into the o2 sensor wire just as shown in the fic instructions. HOWEVER, with the fic installed now i get a constant 1.25 volts on my OBD2 logger when viewing the 02 sensor voltage and my wideband o2 go rich as hell (10:1 afr) NOW, without the fic plugged in and the patch through adaptor plugged in i get the normal oscillating voltage like i should. I DO have the right wire tapped for the 02 sensor.
Oddly enough the map sensor flips out as well. i show about 16.7psiA with the key on engine off with the fic plugged in. With the fic removed and loop plug installed i get normal readings...
ive had NO isues with the map sensor wire or wiring to the fic and i never touched any of it since i installed it. Everything is soldered and heat shrinked.
All of this JUST started after i installed the 1/2 watt 1k resistor resistor into the 02 sensor signal wire.
WTF is going on. this i though plenty of others have done this with no issues. i know Larryinkc has done this with no problems here. Anyone care to shed some light here on my problem. its pretty odd i think.
Im about reading to pull my ****ing hair out...... im serisouly considering the dual rail setup now.....
