1 - 14 of 14 Posts
pass dat....
The ethanol you can get at the hardware store in the paint section, it is about 10/gallon. the methanol which is just about the same can be had at the track for about 3/gallon. If you search dingleweed did an excellent write-up on the 2 a while back. I look it over every now and then.
I use the autocraft -34 window washing fluid(aka the cheep $hit) from autozone. mix that with 2 yellow bottles of heat and that works well. and is more avaliable then the motocraft stuff. I live in chicago and it was hard tracking that crap down.
Hello,
We use 100% denatured alchol from Home Depot. If you are looking to use it primarily for cooling purposes, than mix 50% water with 50% Alcohol. If you are using it for Octane benefits and small cooling as a byproduct, then use straight denatured. We use it for octane so we can run more boost on pump gas.
Thanks T.C.
did you check the autocraft stuff to make sure it doesn't have some sort of silicone in it? or detergent for that matter.
Yes I did, The autocraft stuff is cheep stuff so there only gonna include methyl alcohol and water.
1 - 14 of 14 Posts
