1 - 1 of 1 Posts
2003 HYUNDAI TIBURON 2.7L 6-cyl VIN Code g
FILTERS
Oil Filter........EAO20 AMSOIL Ea Oil FilterOil Filter........SDF20Super Duty Full-Flow Engine Oil Filter - ...Oil Filter........51334 WIX 51334 Oil Filter (D) Air Filter........46318 WIX 46318 Air Filter (S) Fuel Filter........33229 WIX 33229 Gas Filter (O) Cabin Filter........24689
BOSCH SPARK PLUGS
All submodels:
Plug........B4418BOSCH PLATINUM +4 SPARK PLUG [1] Wire........B09015BOSCH WIRE SET
1. Do Not Gap. Gap is not adjustable.
BOSCH WIPER BLADES
All submodels:
Driver side........B40922BOSCH MICRO EDGE WIPER BLADE Passenger side........B40918BOSCH MICRO EDGE WIPER BLADE Rear window........B40920BOSCH MICRO EDGE WIPER BLADE
LUBRICANTS & FLUIDS
Engine Oil
Grade 1......API*
Series 2000 Synthetic 0W-30 Motor Oil
SAE 5W-30 Synthetic Motor Oil
SAE 5W-30 XL Synthetic Motor Oil
Series 3000 Synthetic 5W-30 Heavy Duty Diesel Oil
Above 32°F......20W-40, 20W-50
Above -9°F......10W-30, 10W-40, 10W-50
Below 95°F......5W-30, 5W-40
Manual Transmission,.....GL-4
75W-90, 75W-85W
Synthetic Manual Transmission and Transaxle Gear Lube 75W-90
Automatic Transmission.....SLF[1]
Synthetic Automatic Transmission Fluid
Fluids
Power Steering Fluid.....PS
Brake Fluid.....HB
Clutch Fluid.....HB
1. SLF is Hyundai SP-II Automatic transmission fluid
CHASSIS LUBRICATION
0 Fittings, 0 Plugs
CAPACITIES
Engine, with filter..........4.7 quarts[1]
Automatic Transmission, Total Fill..........8.3 quarts
Manual Transmission, ..........4.6 pints
1. After refill check oil level.
TORQUES
Manual Transmission
Fill Plug.....20-24 ft-lbs
Drain Plug.....20-24 ft-lbs
SERVICE INTERVAL
AMSOIL Product Recommendation and Drain Interval Guide (g1490)
1 - 1 of 1 Posts
