I've had these coilover installed for about a month now. The ride quality is absolutely amazing.ARK Performance brings innovate premium quality damper kits that give precise comfort and balanced handling cornering to sophisticate drivers without loosing there performance results.
ARK damper kits offer different series for your driving situation. SP Series was designed for all your driving conditions with greater performance. This full length adjustment system allows you to set various set-ups to meet different road conditions. And hard rubber upper and lower mount design in SP series absorb noise and vibration to the cabin for quite operation while still offering minuteness suspension proofing. DT Series was developed primarily to serve maximum handling for experienced drivers. This preminum aluminum construction series with special coat on the thread ensure to resist rust and corrosion. And spring rates are tuned to provide high stability and favorable handling characteristics with a neutral front and rear balance.
DT-P
- 0-16 Levels of Adjustable Damper
- Pillow Ball Top Mount w/ adjustable camber
- Spring Rates: 3kg/mm to 14kg/mm
- Adjustable Ride Height
- Aggressive Spring Rates
- Single-Cylinder Design
- All rates from 3kg/mm to 14kg/mm are kept in stock
- Mono-tube shock design for quick reacting and quite dampening operations.
- Electroplated body for protection from corrosion and rust
- All coilover damper kits come with 15months manufacture-defect warranty.
- All Hardware is Included
I've tried virtually all of the damper levels and I am definitely impressed with this system.
At first I was worried about coilovers because of the other threads I've read about other products making the ride too rough. Not the case with the Ark DTP system, even on some of the stiffer settings, these coilovers produce a nice smooth ride.
Before I installed these my setup consisted of stock struts with Eibach Pro springs. Well... this system makes it feel like the Eibachs were an old Cadillac and now it's like riding on rails.
This system gets five stars from me and I highly recommend them!
