Hello everyone. I dont know much about car audio but i think this system would be sufficient enough for my dvd media system.
These are the products i am considering to purchase. Please let me know if these products are any good because the prices are pretty cheap i think
LANZAR MXA412 ,1000 WATT 4 CHANNEL AMPLIFIER $118.95
LANZAR MXA232 1000w 2 CHANNEL DIGITAL AMPLIFIER SUB AMP $59.95
NEW PIONEER TS-W256C 10" 800w CAR AUDIO SUB SUBWOOFER $49.95
2 LANZAR 6.5" 3way 360W CAR AUDIO STEREO POWER SPEAKERS $49.95
I found these items on http://members.ebay.com/ws/eBayISAPI.dll?ViewUserPage&userid=bigbuycity
Here are the specs for each :
NEW LANZAR MXA412, 1000 WATT 4 CHANNEL HIGH POWER MOSFET AMPLIFIER
4 x 125 Watts RMS at 4 Ohms
4 x 250 Watts Max at 4 Ohms
2 x 500 Watts Max at 4 Ohms Bridged
4 x 200 Watts at 2 Ohms RMS
Electronic Crossover Network
Bass Boost Circuit
Variable Phase Shift Control
2 Ohms Stereo Stable
Anti-Thump Turn-On
Tri-Mode Configurable
Soft Turn On/Off
High & Low Level Inputs
Blue Light Illuminated Crossover Control
Power & Protection LED Indicators
Advanced Protection Circuitry
Bass Boost Remote Control
T.H.D: 0.04%
S/N Ratio: 90dB
Channel Separation: 65dB
Frequency Response: 15Hz- 35kHz
Dimensions (W x H x L): 10.47" x 2.46" x 12"
LANZAR MXA232, 1000 WATT 2 CHANNEL MOSFET SUB AMPLIFIER :
2 x 250 Watts RMS at 4 Ohms
1 x 1000 Watts Max at 4 Ohms Bridged
2 x 400 Watts RMS at 2 Ohms
Bass Boost Circuit
Anti-Thump Turn-On
Soft Turn On/Off
High and Low Level Inputs
Power and Protection LED Indicators
T.H.D: 0.04%
S/N Ratio: 90dB
Frequency Response: 5Hz- 35kHz
Dimensions (W x H x D): 10.47" x 2.46" x 12"
10" SubWoofer
800W Maximum Power
350W Nominal Power
Composite IMPP Cone using Interlaced Aramid Fiber
3-Layer Fiber Woven Radial Surround
Impedance: 4 Ohm
Frequency Response: 18-600 hZ
Sensitivity: 87dB/W (1m) 2” Aluminum Voice Coil
Polyester Imide Copper VC Wire
Extended Pole Yoke, Vented Pole
Dual Mass High Power (74oz.) Magnet
Magnet Cover
Extended Excursion design
Two Sets of Spring Compression Terminals
Black head screws
Foam mounting strip
Standard 6.5'' Size Fits OEM Locations
Poly-Mica Coated Woofer Cone
1'' High Temperature Voice Coil
Neodymium Dome Tweeter
Power Handling: 90 Watts RMS/180 Watts Max
Impedance: 4 Ohms
Frequency Response: 50-22kHz
Rubber Boot Magnet Cover
Mounting Depth: 2.48''
Includes Grills, Wires and Installation Hardware
TOTAL PRICE = 278.80 US + (shipping ot south korea) = approx 650.00 US
I cant get a 1000 watt 4 channel amp in korea for under 600.00 US. So I think this is a good deal.
Please give me your opinions..it would be greatly appreciated
btw. I already have 300 watt 6x9s rear speakers. And i think a 10' sub will fit in the stock sub enclosure.
All help is much appreciated.
Thanks.
Bass Boost Circuit
Anti-Thump Turn-On
Soft Turn On/Off
T.H.D: 0.04%
S/N Ratio: 90dB
Bass Boost Circuit
Anti-Thump Turn-On
Soft Turn On/Off
T.H.D: 0.04%
S/N Ratio: 90dB
10" SubWoofer
800W Maximum Power
350W Nominal Power
Impedance: 4 Ohm
Magnet Cover
Black head screws
Foam mounting strip
Impedance: 4 Ohms
Thanks.
