i have a duralast with basically the same stuff as you. never had a problem. Oh and the springs rock diff the drop i was looking for
really? bc i just thought that just because of all the lights and sound.. a normal battery would die faster maybe?i have a duralast with basically the same stuff as you. never had a problem. Oh and the springs rock diff the drop i was looking for
I replied to your other recent post, a battery is a battery. The charging circuit supplies the charge. The battery does not "mystically" make voltage. Maybe a poor connection while changing the battery.I have an optima battery in my 06 V6 and it has destroyed a ton of things in my car. for the first 3 years it was really nice but i tried to switch to LED lights (with the stupid protector box on it) well it has sent my entire car into a tizzy fit and i fix one thing just to have something else go wrong. my recommendation would be to be very careful with an optima in the tibby. I had no idea it would overload things in the car and now im dealing with the consequences
I think your mechanic is not using logic or sound reasoning in his diagnosis. I don't believe the battery will cause that. Sounds like it might be your alternator and integrated regulator allowing overvoltage beyond the 14 or so volts while the engine is operating. Otherwise you have several shorts in the wiring harness from previous damage.I have an optima battery in my 06 V6 and it has destroyed a ton of things in my car. for the first 3 years it was really nice but i tried to switch to LED lights (with the stupid protector box on it) well it has sent my entire car into a tizzy fit and i fix one thing just to have something else go wrong. my recommendation would be to be very careful with an optima in the tibby. I had no idea it would overload things in the car and now im dealing with the consequences
