1 - 3 of 3 Posts
Hello guy’s
Any one here that have idea for replacement of BCM. I have issue on my BCM and my car wont start and no power at all and i check my BCM totally burn out and can’t be repair. Now i found donor of BCM in junkyard, my question is is i took that BCM and i stall in my car, my car will be fine or i need some programming
My Car details:
Hyundai Tiburon
V6 2.7
A/T 2WD
2005 Model
Car donor:
Hyundai Tiburon
V6 2.7
A/T 2WD
2004 Model
any idead if the BCM odf the donor it will be fit on my car i check the conector and all pin all are match on me
but i still confuse if that BCM will be work on my car
Please help any idea for This....
thank’s for the reply bro. I already Figure out and now my car are back in track. i just bought a BCM in Junkyard. i just make some tricks to fit that use BCM in my Tibby and everything are fine no need programming. Also the part-Number of BCM is nonsense just find the same Year model.
If you want that tricks DM is the answer total cost Use BCM in junkyard 70$ + 2$
For more details DM
1 - 3 of 3 Posts
