Hey guys so I'm getting a p0102 mass or volume air flow circuit low code on my 07 tiburon gt (112000) miles auto trans from my best guess is to replace the maf sensor itself knowing these cars only want oem parts what brand should I look for? Also was thinking of replacing the wire that connects to it
Seimens MAF sensor.
Your best bet would be to replace it with the OEM part. Although they are more expensive, they will save you headaches down the road. Alternatively, you can try removing it and cleaning the hotwire with MAF sensor cleaner, following the instructions on the can. If that doesn't work you could also try local junkyards to see if they have any V6 tiburons and take that MAF, but be sure to clean it prior to installation.
