1 - 20 of 85 Posts
Hi guys,
I'm in the process of building a fresh 2.0L - G4GC Beta-II with forged internals after recently throwing a rod in a rather explosive manner :p
I originally turbocharged the car back in October 2012 with a Kinugawa TD05H-20G and Jattus tubular / equal length manifold. This setup has proven to be a beast on the street, it's also been also fairly reliable. I like to take the car on track days (mainly circuit) every 2-3 months so I can put myself and the car through its paces.
My previous configuration was a stock Beta-II pushing around 400whp. I just had a decompression plate to lift the head and lower the compression to 8.5:1. The engine was otherwise completely stock / unopened. I have to say, i'm truely amased of the strenth of the OE components. I was making double (almost triple) the factory HP and the engine hasn't missed a beat over last 7 years.
Bottom End Components:
  • Pauter X-Beam Rods
  • CP Pistons, 9:1, standard 82mm bore
  • ARP 8740 Main studs
  • ARP 2000 rod bolts
  • ARP 625+ Head studs
  • King Bearings (AM material) for mains / big end.
  • Lightweight Crank Pulley from Alutec
  • Boundary Racing Billet Oil Pump Gears
Head:
  • Camshafts - stock with 270 / 264 re-grind.
  • Valve springs - Brian Crower 4G63
    • OEM locks and retainers with stock valves.
  • Arrow Cam Followers from a Renault Clio (CF137K16) - machined to fit.
  • Ported intake and exhaust trace
Transmission:
  • Stock GJ93 - 5-speed Gearbox
  • Custom gear set from Elite Racing (1st gear is straight cut, 2-5th are helical)
  • Gears manufactured from aviation grade S156 material
  • Hardened and REM finished so should be much stronger than stock
  • Larger input shaft / spline (24.9mm, 23 tooth) same as the Mitsubishi Evo 9
  • Stock bearings and synchro’s with temperature sensor boss welded on
  • Quaife LSD (QDH8B with Mitsubishi Speedo Gear MD717879)
Misc:
  • ClutchMasters 7.25” Twin Disc (ceramic + fiber tuff rigid combo)
  • Push-clutch conversion with throw-out bearing, clutch fork and retainer from Atelier HP
Missing Parts:
  • Race Bearings (rods and mains) – I can’t find the part numbers for ACL or King bearings
  • Camshafts – I can’t find any off-the-shelf products (considering a custom re-grind)
  • Lightweight Aux Pulleys - because the stock ones are ugly
Electronics Package:
  • Link G4+ Thunder ECU
  • Coil-on-plug conversion for sequential injection (Nissan R35 coils)
  • Injector Dynamic 850cc injectors (stock fuel rail)
  • Walbro 190LPH fuel pump (stock lines)
  • E-Throttle conversion with Bosch throttle body / pedal
  • MAC 4-port boost solenoid
  • Multiple EGT probes (pre / post turbo)
  • Dedicated LSU4.9 wideband + AEM Failsafe gauge
  • OEM knock, cam, crank, ECT sensors
  • OEM CVVT, 2 wire oil valve on the intake side
  • Motec fuel pressure, oil pressure and gearbox oil temp sensors
  • Launch control, traction control, flat foot shift, downshift blip and all that good stuff
I don't suppose anyone has the race bearing part numbers from ACL or King etc, I'm really keen on upgrading the bearings as i doubt the OEM bearings can handle 500-600whp?
I used ACLs in my old 2.0l build as well as Jonathan's race motor. I'll find the part numbers for you. I also recommend a dw300 or 65c pump if you want to run flex fuel.
I can't find my build sheet right now but I do remember I had to search for engine code g4gf not g4gc. I see them on ebay for the g4gf.
Discussion Starter · #5 · (Edited)
This was the start of rear-end upgrade... I did all this at the same time. The improvements on the road and track are awesome!
The upgrade consisted of Ingall arms, poly bushes, ultra racing swap bars, braces, oem trailing arms, subframe and swap bar locks.
134937
134940
134941
134994
Kind of looks like I've crashed into the house :)
134942
Rear-end up in the air, posing nicely... She's all ready for it...
134944
Nice and lubed up in an attempt to remove all the rusty crap... I ended up cutting the bolts with the angle grinder in the end, they were just too far gone.
134945
I decided to paint the front and rear spindles with Hammerrite before installing the poly bushes.
134946
I also painted a few bolt that I forgot to order up... 90% of the rear-end hardware was replaced with OEM parts from the STEALERSHIP!
134947
Discussion Starter · #6 · (Edited)
In didn't quite get the rear-end finished on Saturday so i decided to work into the night.
135007
Not bad hey... :)
134948
Sunday morning I started work on the front-end... I installed the new wishbones with poly bushes, end-links, track-rod ends and painted the spindles.
134949
I decided the OEM replacements were just too expensive especially after spending a fortune on the rear-end hardware so I opted for Moog / Blueprint OE style replicas.
134950
I also installed new wheel hubs and bearings whilst i was at it.
134951
This wasn't a particularly fun job cutting out the brand new rubber bushes but I'm really glad I replaced then with poly.
It really tightened up and sharpened the steering response, you just have to be careful when you sneeze!
134952
I think i've posted about this before but I had a set of poly engine mounts made by BRD.
134992
134993
Does that old spring look like it's bulging to anyone? I replaced as the rear-end was sitting wonky... In face it still is as one side has a 2" gap from the wheel to wheel-arch and the other maybe 4-5". I've had the alignment done twice since them but can't figure out what's causing it. Fingered crossed the chassis isn't twisted.
134955
134956
Discussion Starter · #8 · (Edited)
This come in handy when i grenaded the engine at the track last month!
134972
Saw this when i was working in Madrid and just had to take a photo :)
134973
Just charging up the ECO friendly Coupe LOL
134974
Discussion Starter · #13 · (Edited)
Thanks :) It's nice looking back over the last few years and going through the photos on my phone.
You know it's been over 7 years in the making and it's great to be able to reflect on the build. I've learnt so much from this forum... When i first started working on the Coupe i didn't know how to change the oil or spark plugs (in fact i had never worked on a car prior to the Coupe) so it's been a massive learning curve getting the car in to it's current state.
Anyway... I may have got a little distracted and posted like a million photos above... On to the current matter at hand:
135006
134995
134996
134997
134998
134999
135000
135001
135002
Discussion Starter · #14 ·
Bearing wise I've brought these but unfortunately they don't fit! :(
I can't seem to find anyone who makes performance bearings of the Beta-II...
135003
135004
135005
Yeah 4g63 are different. Did you see my comment about G4GF bearings? Search ebay for G4GF bearings and get a hold of the seller of the ACLs I bet they can get you what you need.
Awesome build very interesting what you're doing with the transmission that's one of the main downfalls of the beta the 5 speed ,and yeah their us a way to get cal bearings I just cant remember how
Discussion Starter · #18 ·
Thanks, i've just messaged a few eBay sellers to see if they are able to source and supply the bearings.
After speaking to ACL and King Bearings directly they have both told me they only make standard bearings for the Beta-II. Apparently they don't make the tri-metal performance bearings for Hyundai's...
As you guys have used performance bearings with your builds i'm guessing they must be from a different engine? Or maybe there was a small batch run and they have been discontinued?
I used the G4GF race ones. They may be discontinued though. In most cases standard ACLs are fine. You can even have them coated which will be better than the race.
1 - 20 of 85 Posts
