1 - 2 of 2 Posts
How do I remove my cd player from my tiburon. I'm getting a new car in an hour and want my deck back from my current car.
If it is a 03 or up, pull out the ashtray, pull on the corner of the bezel surround for the radio and the HVAC controls, it will come off so pull till it does. Once off, disconnect the connectors that are holding it on, and put to the side. Then remove the four screws that are holding the install kit or brackets that are holding radio, and pull out he radio and disconnect the wiring harness and antenna. Then grab the factory and reverse, not really that hard, only tool you need is a Phillips screw driver! L8R
1 - 2 of 2 Posts
