1 - 16 of 16 Posts
Ok its auto and when I press the pedal makes a clunk sound like maybe hitting something but when I look at it when I rev doesnt hit anything whats the issue?
Its FUJITA!!!!!!!! Besides that...are you sure its the intake?
its probably hitting up against the hole it has to go through to make it into the fender...did you line that hole or did you just widen it and stick the pipe right down in there?
anything man. make sure u bent the lip DOWN on the hole and then wrap the pipe or hole in something. I used aluminum tape
Should come with a grommet to put around it, if not cut up a small tube (1/4" or so) and slip it over the hole. Make sure you have the intake tight though....it shouldnt have enough play in it to hit that hard if even hit at all.
I used some double sided foam sticky tape about a 1/4 or 1/2 inch thick from home depot. It was less than 5 bucks and worked pretty nicely.
its highely unlikely its hitting against anything else. You need to wrap that hole with something, otherwise you will probably end up putting a hole in your intake eventually...
put something like a gromet around that hole (or tape or whatever) and see if it stops. Also make sure where you bolted it up (half way down the tube) is secure and tight.
Discussion Starter · #12 ·
thanks so goes in the whole ! ahh I c hehe gonna wait till my dad comes home and see if he has anything to stick in there!
Looks so much better lol!
Yo man, line that hole with something and clean your ground connection!
Rust FTL!
good to hear man
1 - 16 of 16 Posts
