Hi Guys. I have a 2008 Tiburon, 4cyl. About a week ago the car wouldn’t start. I thought it was the battery due to the cold weather...it wasn’t that. I checked the fuel pump and it was working fine. So then I checked the spark plugs and I had no sparks. The plugs were fine. So I thought it was a problem with the ignition...I wiggled the wire to the camshaft sensor and the car started. So I tested the connector to the sensor. It gave me 4.9V to the middle wire and the signal wire had 0.28V. I have no codes in the dash. Just wondering if this is probably a wiring problem or a sensor problem. How much voltage should be going to the sensor? Every time I have to wiggle with the sensor to get the car to start. I did a resistance test in the sensor and it gave me 500 and 1400 reading. Not sure what’s going on. Any help is appreciated
Thank you so much
Thank you so much
