I recently had an issue with the car the alternator bearing in the pulley seized but I immediately had the car stopped and pulled into a parking lot cause the lights vame on indicating alternator had stoppwd working (obviously because the belt snapped off from spinning on seized pulley)and inspected it I had I got a towed home and when I inspected everything I found that the pulley was seized the belt had broken and the radiator must have built up pressure due to the water pump not circulating the coolant so it cracks the plastic top of the radiator now the car still ran and started fine so I replaced the alternator the belt and the radiator fresh coolant and all the car ran I burped the air out of the system and when it was done I took the car off the jackstands and I shut the car off I topped up the oil it needed like barley any but i like to keep it on mark at all times lol and topped with the coolant and then I went to start the car again like 5 - 10 minutes later and it will not start just cranks I checked everything in the car so far I'm not getting any spark as far as I can tell from doing a spark test there's no spark going to the ignition coil but I had the fuel pump kicks on and primes you can smell gas up in the front by the plugs when checked so I really don't know what to do i had done research on the matterbI had replaced the crankshaft and camshaft sensors last year and they've been working ever since so I'm not 100% convinced that it's those I have the plugs are good still and new wires and doesn't make sence the car literally ran for half an hour as I was burping air out of the car and then won't start back up I've also tried spraying starter spray into the intake no luck its been about a week now no start I'm wondering what the happened or hopefully it's not an immobilizer issue but I'm thinking if the immobilizer wouldn't let the car crank would it?
Car Details:
2008 Tiburon GS/Sport Package
I4 2.0 4-speec automatic
Canadian Tiburon
Any help or information would be greatly appreciated because I do most of work myself cuz I can't afford to send it to a garage so I'm here troubleshooting everything myself
Car Details:
Canadian Tiburon
