1 - 20 of 25 Posts
I have Centerforce Dual Friction Clutch kit (pressure plate and disc) that i never installed on my car for not getting enough money to install them then just decided to sell my car and got no use for this system. I also have the original Throw out Bearing (Centerforce) for this kit that needs to be purchased separetely.
Plus also F1 lightweight Flywheel that I purchased for this kit but as well...never used them. EVERYTHING IS NEW!!!
Im letting it go for ONLY 550 with FREE SHIPPING!!! to anywhere!
Here are some pics
Is this for v6?
Also, what is the rating on the clutch, like what is the stage equvalent? I'm running pretty much stock except for I/E so I'm looking for a stage 1 or 2. Don't want too much bite....
Checking, is this for the 5 or 6 spd i've heard there was a difference between the two, also, v6, and stage, im looking for a stage 3 but could live with a 2 for the moment
Stage 2
I bought it from a friend that used to own an aftermarket store...
I was goin to put it on my 03' Tibby 2.0L i4 5 spds + reverse
dont know if it will fit others...
Awesome clutch, i have it in my 04 GT 5sp and it has never slipped on me. All my friends have complimented me on how well it actually grab's. Free bump and good luck with the sale!
i want to ask too, its for the 5 or 6 speed, sprung or unsprung, my clutch is slipping again so, maybe i need one, but need to know if this is the right one.
Stage 2
Cuold you post the part # , want to check fitment .
also , are you selling just the clutch ? if so how much ?
I dont need the flywheel , have Fidanza .
Thanks
Discussion Starter · #13 ·
Just checked at Centerforce web page and it match as DF178157
TOB is 134
there is!
Actually I think it can fit v6 too or something but not sure...
Id prefer to give everything out at once for an easy transaction and complete system...or else if I get offered by one side the clutch and the other the light flywheel, I may part out...
Year Application
Size Metric Size Inches Spline
Pressure Plate:
Disc:
PP & Disc:
CF I CF II Dual Friction DFX LMC Series T.O.B. Flywheels
CF I Disc CF II Disc DF Disc 4-6 Puc Solid LMC Disc Align Tool
CF I PP & Disc CF II PP & Disc DF PP & Disc DFX II PP & Disc LMC PP Pilot Bearing
HYUNDAI
TIBURON
2003. - 2007. 2.7L V6 ENG. 5 SPD FROM 4/03 6 SPD FROM 2/03
225 mm 8-7/8" 7/8"-20
Notes: PULL-TYPE CLUTCH, FOR USE ON DMF ONLY, SOLID DISC HUB.
Pressure Plate:
Disc:
PP & Disc:
- - - 11292271
Call - 134
Call -
- - - 23292271
Call - 50020
- - DF292271
01292271
Call - -
go to top
2003. - 2003. 2.7L V6 ENG. 5 SPD. TO 3/03 6 SPD. TO 1/03
215 mm 8-1/2" 7/8"-20
Pressure Plate:
Disc:
PP & Disc:
Call 11178157
Call - 134
Call -
Call 23178157
Call - 50020
- CFT178157
DF178157
01178157
Call - -
Notes: PULL-TYPE CLUTCH, FOR USE ON DMF ONLY, SOLID DISC HUB what the hell does this mean??? sorry for asking this!!!
damm it this is not for my car.
Discussion Starter · #18 ·
Yeah the page is so ****ing confusing!
Look Ive been told that the page isnt right refreshed, so I might give a call to them and just verify the info. Cuz I was told this would fit an i4 (my car) from the pro shop that was goin to make the job...
but at the page it says that it also fits V6 :confused:
well now i get it, the dmf its dual mass flywheel, yes, maybe every body, knows that, but i dont, so now i know hahahahaha, so no ponshoe, this maybe fit the 5 speed but my car was whit the dual mass flywheel, then i need the other, not this one, i cant use it, cause i have a fidanza flywheel, so, i need to use the oem one, damm it.
sorry men, maybe next time
COLD
out
1 - 20 of 25 Posts
