Check out the BIG NGM SALE!!!!
You guys gotta see this..
http://www.newtiburon.com/forums/showthread.php?t=87874
hahaha you posted a link for a thread thats in the new thread section...12secTib said:
I think so lemme look around..ddemlong said:hahaha you posted a link for a thread thats in the new thread section...
Hey off topic, you have any vids of your assassin tib at the dyno?
damn it looked like you hit 12psi12secTib said:I think so lemme look around..
Yes it was hitting 11 to 12 psi.........ddemlong said:damn it looked like you hit 12psi
Do it bro now is the time. This sale T.C. is doing is awesome. :3_nosthumstaw512 said:<<<<<< might step into the world of f/i
thats pretty sic, im putting in the Assassin tomorrow with chris and ian, it shouldnt take up very long, most complicated part is wiring in the extender to the neo.12secTib said:Yes it was hitting 11 to 12 psi.........
Sorry Im not much help with this because I have a Mafterburner and the wires on the extender are the same as the Mafterburner so its fool proof. Did you not get a Mafterburner? If you did I would for sure use it.ddemlong said:the only reason i say that is casue the red goes to power and the back to ground, but then im only left with 2 wires... unless i take the extenders wire and soder it to the point were the maf meets the neo and the neo meets the ecu input wire
na he gave me a fuel pump and took 200 off the total price cause i have the safc neo, TC says it will wire into it.12secTib said:Sorry Im not much help with this because I have a Mafterburner and the wires on the extender are the same as the Mafterburner so its fool proof. Did you not get a Mafterburner? If you did I would for sure use it.
You can connect the extender anywhere between the neo and the ecu.ddemlong said:na he gave me a fuel pump and took 200 off the total price cause i have the safc neo, TC says it will wire into it.
is that all you did was soder the extender wires to were the maf meets the mafterburner, and again were the mafterburner meets the ecu?
05Tib said:im thinking Sniper... then get a fuel tuner later and tune it all
