i've never had aftermarket wheels before
i ordered some wheels/tires
i do not believe they included lugnuts or hubcentric rings
when i get my wheels is there any way to tell by looking at them what type of lugnuts i'll need? can someone also confirm the tiburons (05) lugnuts are 12x1.5? i have gotten the impression that there are different styles of tuner lug nuts.
is there any way for me to measure the center bore of the wheels accurately enough by myself to order hubcentric rings should i require them?
what is the bore of the tiburon (05)? i'm talking about the smaller inner diameter i'd need for the ring.
the wheels are ro_ja
Here are the lugs I just bought...
http://www.midwayautosupply.com/showproduct.aspx?productid=7967&affiliateid=10050
Those are the 12 x 1.5 like you need and they are very small in diameter so they should fit most aftermarket wheels. I know the bore for the '03 GT is 67 mm, but not sure if it's the same for the '05 or not. I bought my rings at a tire store nearby and they looked up the size to verify it was correct...so a shop should be able to tell you.
would those lugnuts work for me too? i have hp design lightning rims
