1 - 3 of 3 Posts
hi, question to anyone who clamped the map voltage.
what pin is the map signal wire on i4? or did you clamp it sensor side? if so, which pin of three is the signal one?
hm, show me a pic of the map wires and I can tell u, I know one is a ground, one is a temp, one is map (v) -- I have it clamped on my car with the eManage-U, but I remember what wire it is...
I just can't go out and look at my car right now cause it's so damn nasty out...
nah, that won't be a problem sensor side. black will be the ground, the power +5v should be red or something, anyways, easily measured and to the third i'll insert the zener diode inline , i don't want to disassemble the ecu again , no way :D
1 - 3 of 3 Posts
