yesMartin said:Can they be done the same way as the 03-04's?
im 97.3543% sure you canMartin said:and can you use the 03-04 clear tail light covers on them?
The clear covers for the 03/04 are not perfectly molded, they are a lil bit bigger than the stock covers. Some cutting/dremeling is required to obtain a good fit.Martin said:Hey has anyone tryed to clear a set of 05 tails? Can they be done the same way as the 03-04's?
Thanks
Ya i know they need adjusting to fit the 03-04's i did the set that are on my car now and went LED in them, A friend of mine wants me to do a set of 05's and I was just asking if they could be done the same way.tibjay909 said:The clear covers for the 03/04 are not perfectly molded, they are a lil bit bigger than the stock covers. Some cutting/dremeling is required to obtain a good fit.
I think it is the cruise control that doesn't work right.Shift21 said:when you put the led in i hear the break lights do not work right.
no the brake lights work fine, you will loose your cruise control if you do not buy a resistor and chnge the wiring on the back of the tail light.Shift21 said:when you put the led in i hear the break lights do not work right.
You might not have the right led's, or they are wired wrong, you need the led's that get brighter(like hte stock bulb)Shift21 said:my bad,I just messed mine up then lol with the LED ligths in they do not light brighter when i touch the breaks. The custom tail ligthts are a must, just finished mine. The DIY was AWESOME
