1 - 20 of 26 Posts
yeah bro, i have the same prob with my flywheel.. the thing is, the fidanza flywheel is 9.5 lbs which is honestly way lighter than it needs to be. a good l/w flywheel is 12 or 13 lbs.. the throwout bearing is whats making the chatter because the flywheel is just going crazy fast because its way too light... its not necessarily a bad thing, btu you might be able to get a better throwout bearing or something to reduce the chatter, other than that theres not much else you can do but listen to it, lol
vids dont work? what flywheel do you have also? i have the stage 3 and a fidanza and it chatters all to hell. i was told that the throw out bearing is the reason but idk because its was new also.
Try right clicking and save the file... the flywheel is a Clutchmaster as well
ok i cant get the vids to work but i think i know what your talking about out side the car you hear it push in the clutch and it goes a way right?? its from the light weight fly wheel. what is happening is your hearing the chatter from the idler shaft its plastic thats why Hyundai used a dual mass its spring loaded to absorb the noise
^ exactly.. basically.. our cars really arent made for lightweight flywheels to be installed, so when you do it, you just kinda have to live with the racket
hmm i have a spec stage 4 clutch and a 9lb fidanza flywheel and my engine sounds just like it did stock. idk
Discussion Starter · #17 ·
i'm not sure how heavy the CM flywheel is.... i bought it from rippmods a long time ago in a GB
I bought an ARK flywheel and it's 14.2 lbs i hope when I get it installed it won't chatter as much
Ive got the VHR clutch and flywheel and I get a bit of chatter but nowhere near that bad. I guess thats the difference an aluminum flywheel makes. I think i'd go insane if that was a daily driver.
1 - 20 of 26 Posts
