I got headers and second sensor on the rear header did not fit so i extendet wires - does anyone cnows if it is ok to extend wires on CO2 sessors
It's O2 sensor, and as long as you use the same gauge wire and solder it properly you shouldn't have a problem
definitly solder and wrap the connections good. those wires are open to the elements esp if its your bottom ones (i assume bottom sense ur extending wire)
The back O2 sensor wire should reach , what headers did ya get ?All I did was take the harness out of its holders and relocated them .
