1 - 5 of 5 Posts
I've changed the motor 4 times...long story..recently the motor was running fine ..now it won't fire ..no power to the sensors..when I jump power.tje one that should read 0-5 reads .2 the center on plug..it's crazy the the two top fused in the fuse box under the hood only register .32 volts instead of 12...I don't even know how that's possible..please help me ..I'm disabled..so have to fix it myself..and it's whipping my butt
Can you check crank position sensor?
I changed it with one I know worked...here's a crazy. In the fuse box the sensor fuse and one above it only registered 3.5 volts..even when you run a 12 to the fuse there's only 3.5 at the srnsors
Common issue (especially with engine swaps or intake manifold work) is missing/loose/painted/corroded main engine ground from upper intake to firewall. That will force smaller wires to handle large loads which they are not designed to do.
Next can be failing battery cables either at the ends or along the length.
1 - 5 of 5 Posts
