1 - 13 of 13 Posts
am i the only one whos broke 3 of these things now, any one got any ideas that i can fix this silly little problem, i mean it starts to move and about 1/2 though the stroke of it , the alluminum tab snaps off, i can use a rail bar and get the it fully stroke, or am i the only one thats having these problems
what tensioner are you referring to?
are you pushing it the wrong way i happen to know that can break it
Pics? I only replaced mine once. I was going to say if you're getting belt slip you need more wrap around.
ill get some up, im using a fan cluthc bar! and no im not going the wring way, i think the spring in the tensioner is llocking up or binding so it only travels 1/2 and this has happened 3 times now i was lucky because i was able to slip the belt on with a realy small long screw driver but i was wondering if there was some kinda recall or theres something u supercharger guys were doing to avoid this ! but it may just be one of those piss poor desighn!!
ib4screennamehasmeaning.
(probably doing it wrong.... i.e. push down).
You must be using the wrong tools to do the belt, I've still got the O.E tensioner and it works fine , there's nothing wrong with the design , just something wrong with the tool or the person using the tool:nerd:
Don't you just put the wrench in a push it down?
I mean, it's probably easier with 2 people, but come on! :einstein:
I had one break on me, tough on the knuckles, had the blower off countless times, different size belts, etc. Three you freakin' broke, man, sumthin' ain't kosher!
i know exactly what your talking about, my first tensioner did that, it felt like the spring or whatever is inside it was jammed and it wouldnt move, i put too much stress on it one day and the aluminum around where the wrench goes in snapped, so i got another one, and its worked perfectly since
Discussion Starter · #13 ·
these things are turds but oh well, im telling u it snapped every time i put on a new gates belt the other day exactly the same as the oem one!! maybee that my luck!! get 3 in a row that have weak points in them, i mean they are all aluminum and really naroww at 2 points, i bet f i buy a new one and take it to work and weld a bit of reinforcement right there would be fine!
1 - 13 of 13 Posts
