1 - 8 of 8 Posts
ok my dad tells me that my CVC passenger joint is goin out..anyone know wat that is a nd how much?
That would be a "CV Joint" Constant Velocity Joint. That is the part that goes between the transaxle and the wheel bearing. It allows that wheels to spin while your wheels are turned. It pretty much is a flexible axle shaft. It has that ribbed rubber baffleing around it.
It will cost a couple hundred bucks just for the part(there is a core charge on that part). If you go to the dealership, it will probably cost between $600-$1000.
DeathMetalDan said:
2000elantra?? are you lost??
About the CV joint, try a web search for Hyundai parts, make sure you know what your doing though man, i belive there is an inner and outter CV joint on this car.
Are you doing it or is some one else replacing it for you??
http://www.trademotion.com/partlocator/index.cfm?siteid=214026
This will take you to NewHyundaiParts.com, You might find what you need there.
MUCHO THANKS!
1 - 8 of 8 Posts
