If you've ever done it on a foreign car like a honda or toyota its the same thing. Everything is very accessible, unlike some domestic cars (like the crown vic i dust did :3_frusty: ) The only thing that i did that was retarded was break one of my rear seatbelts. You have to remove the bolt holding it to move it out of the way to get to the bolts for the shock. I let it fall down to the seat so it retracted all the way and now it doesnt unlock even if i take it apart and wind it out. You might be able to work around it with a machine wrench and some patience but its probably just easier to take it off and slide the belt in between the seat or something so it doesnt retract all the way. Other than that its a piece of cake.Vidfinnx said:Ive done springs on different cars before but never one of these, is there a diy somewhere on these just so i know what i need and dont run into any suprises, thanks![]()
coolstrozak said:If you've ever done it on a foreign car like a honda or toyota its the same thing. Everything is very accessible, unlike some domestic cars (like the crown vic i dust did :3_frusty: ) The only thing that i did that was retarded was break one of my rear seatbelts. You have to remove the bolt holding it to move it out of the way to get to the bolts for the shock. I let it fall down to the seat so it retracted all the way and now it doesnt unlock even if i take it apart and wind it out. You might be able to work around it with a machine wrench and some patience but its probably just easier to take it off and slide the belt in between the seat or something so it doesnt retract all the way. Other than that its a piece of cake.
Don't worry about it. If you take the seat-belt thing in your hand and balance it,,the seat belt will come out.cool thx man, i think imma zip tie my seatbelts up so as they dont retract
dude you really need to learn how to use the search button..... You have like one thread a day on somthing retarded that can easily be found if you LOOK!!!! stop being a lazy a$$!Vidfinnx said:Ive done springs on different cars before but never one of these, is there a diy somewhere on these just so i know what i need and dont run into any suprises, thanks![]()
mine didnt haha... i have one seatbelt that works and one that... well doesnt.... I got it to come back out but i kind of had to break it :3_chubby:ViolentB said:Don't worry about it. If you take the seat-belt thing in your hand and balance it,,the seat belt will come out.
yea, that worked just fine for me as well, worked on both sidesViolentB said:Don't worry about it. If you take the seat-belt thing in your hand and balance it,,the seat belt will come out.
i tried that and it didnt work on one side. I took it apart and sprung it and wound it back up but somethings screwed up with it. One of these days ill have to pick one up i guess...sigh*MoogLe said:yea, that worked just fine for me as well, worked on both sides
im not lazy im just Dee dee dee :bigDuhard hey the taller springs go in the front because of the engine weight correct?myslow1 said:dude you really need to learn how to use the search button..... You have like one thread a day on somthing retarded that can easily be found if you LOOK!!!! stop being a lazy a$$!
EDIT:
http://www.newtiburon.com/forums/showthread.php?t=84151&highlight=spring+install+DIY
http://www.newtiburon.com/forums/showthread.php?t=594&highlight=spring+install+DIY
http://www.cardomain.com/ride/2275902/2
that took all of about 2 minutes.... Vid you are the laziest person on this site....
no of course not. The taller springs go in the back to give your car that aggressive look :2_twistedVidfinnx said:im not lazy im just Dee dee dee :bigDuhard hey the taller springs go in the front because of the engine weight correct?
ok now by asking another dumba$$ question that you could have searched to find the answer... it pretty much proves my point.... If i was a mod i would lock every single one of your threads.... You have been here long enough to know how to use the little search button.Vidfinnx said:im not lazy im just Dee dee dee hey the taller springs go in the front because of the engine weight correct?
