I want to change my inside dome lights, but I dont know how to take the cover off. Does anyone know how or has done it. Thanks i appreciate it. I have an 03 tib
Should I put the screwdriver between the lens and the light switch holder cover??Tiburon628 said:theres a little slot on the lens.. put flat head screw driver in it. and pry it off.. BE EASY.. dont break it!
no.. where the lens meets the sunglass holder there will be a little slot, look at the middler of the lens and then look down a little bit on the bottom of it, yo will see the little slot.. stick the screwdriver in that and pull lightly.. DONT be rough.mirador1931 said:Should I put the screwdriver between the lens and the light switch holder cover??
interested too. the $50 superbrights led's from soulful are bit too pricey for me...where do you purchase the right bulb size in white? Are they cheap?
THATS NO LIE... I got mine from shark racing as an Xmas gift. They work fine.194 wedge
anywhere...and i mean anywhere... any car place/walmart dept store.
it is the most common bulb. i changed mine out to red. hated the bright.
just get a good name, like sylvania or philips or something and it should be good.
194 wedge? thats the size?194 wedge
not familar with any bulb size other than headlight & fog light bulbs..
are those de3175? for some reason, a lot of places say those are the dome lights when clearly they are not.I got dome lights today from an ebay guy and they came but they look like those silver tipped lights you find in the trunk light. How is this suppose to work in the dome light that is a rounded bulb with a flat plastic piece that slides in?
