1 - 10 of 10 Posts
I have Eibach pro-kit with 1.1 drop all the way around. The bolts on my front shock, spring arms keep comming loose causing a loud clicking sound when I turn the wheels one way or the other when Im backing up or somtimes under acceleration. Dealership supposidly tightened them and that worked for awhile but slowly the problem is comming back. I wonder if they only tightened one side down factory spec and now the the other side is doing it. Anybody else have issues like this with aftermarket springs?
hit search, there is a cure for this. Requires you to reverse something.
and that somethin will be found when u use the search buton.
I had the same problem with my sportlines and because of guys telling me to use the ''SEARCH BUTTON'' I couldn't solve the problem for a long time. Anyways, I changed my strut mounts and the problem was fixed.
Discussion Starter #4
Changed your strut mounts with just new factory strut mounts?
Yes, I changed it with the OEM strut mounts.
Discussion Starter #6
How much did that cost you?
I can't really remember but it was like 20 BD including labor charges which is around US$55. But, I think you shouldn't compare the prices with Bahrain because there is no tax and labor is very cheap.
Discussion Starter #8
Damn, well here they kill us on Labor.
If you believe that the problem is because of the strut mounts you can buy the strut mount from the dealer and fix it yourself if you have the proper tools. By this you can at least save from labor charges.
Discussion Starter #10
This is true. Thanks for the help dude
1 - 10 of 10 Posts
