1 - 2 of 2 Posts
My 2004 Hyundai Tiburon runs fine,but if you turn off the engine wait for a while, re-start then has problem, the engine will start and run for half a second, then it stalls instantly. The only way to get it over is step on the gas, then start the engine, then let it runs at 2500rpm for about 10 - 15 seconds, then the engine is fine. No codes after scaning the ecu. Any solution?
Sounds like possibly a clogged fuel filter or failing fuel pump. Try turning it to on (but not start) a few times to prime the fuel pump and see if it starts then. If so the pump may be on its way out. Either way if you've never replaced the fuel filter and strainer I'd do it. See my DIY here: DIY: - Fuel Filters | Hyundai Tiburon Forums (newtiburon.com)
1 - 2 of 2 Posts
