1 - 3 of 3 Posts
· Registered
2008 hyundai tiburon
2.0 4 cylinder
automatic
ive had it tested at auto zone code reads vaccume leak. it started right after i had the fuel pump replaced. When i disconnect battery it will stay off for about a day then come back on...
what are some things i can check or fix ro get it to turn off? thanks
· Premium Member
2006 Hyundai Tiburon SE
There isn't a "Vacuum Leak" check engine light or trouble code. Please provide the precise codes you received.
· Administrator
Agreed.
iseeowls, please post the codes as pulled, NOT the description!
Likely they didn't get a hose on, cracked a plastic fitting, etc. It is likely a code (CEL or MIL) related to the EVAP system. Something is not right, the ECU gets pissed off and trips a code. There are 3(?) EVAP codes related to leaks......small, medium, large. Large are usually easy to find.
1 - 3 of 3 Posts
