Anyone know a good air to oil cooler that will easily fit the tib?
good.... no problems yet. This oil cooler also allows for a bigger filter up to PH8 (I believe, a very common, huge *** truck filter).Awesome! how did it work out for you?
Just wondering where you located your dual remote filter setup? I'am a AMSOIL user also.I installed am Amsoil dual remote filter set up which allows the use of a bigger full-flow filter, also a by-pass filter which filters down to less than 2 microns @ 98% efficiency! Most good full flow filters are good to about 15 microns, much better than that and there is not enough flow of oil or it will just open the bypass valve in the filter and allow dirty oil to travel around your engine. Not only did I pick up about a quart and a half of extra capacity I have more cooling because of the double filters and the aluminum filter mount, oh yeah the synthetic oil helps too!
I mounted it up under the battery box. I drilled 3/8" holes and installed 1/4-20 rivet nuts in the metal and bolted the mount to them and ran the hoses to the existing oil filter mount.Just wondering where you located your dual remote filter setup? I'am a AMSOIL user also.
Thanks for the info. I like the idea of being able to run the extra pertection and oil capacity. What was the part #'s for the unit and filters.I mounted it up under the battery box. I drilled 3/8" holes and installed 1/4-20 rivet nuts in the metal and bolted the mount to them and ran the hoses to the existing oil filter mount.
Thanks again for the info. I'll probably go that route when i get my Tib back.The dual remote kit is BMK-13, the full flow filter is EaO15, the by-pass is EaBP90. The rivet nuts are available through Grainger and I'm sure many other hardware suppliers. Yeah I'm a dealer, any questions you have I can probably answer, I have installed a few of these.
It's just a matter of fast changes in oil temp causing the oil to be of inconsistent viscosity and also it causes it to break down faster... A little cooling is ok (but not really necessary)... but like MisterTib said you dont want to over do it.hmm..i'm just trying to find a way to prolong my engine life (without getting rid of the SDS (haha very funny)
