1 - 20 of 53 Posts
Discussion Starter #1 (Edited by Moderator)
The healights are pretty easy to convert. All you have to do is swap out the wiring harness.
Here is a one picture wonder for you all:
Re: DIY: 05 Headlight Wiring conversion to fit 03or04
u can just swap out the whole harness, i did mine about a yr ago but im pretty sure i had no wires left over, i could be wrong tho. but i just swapped out the whole harness. its kinda tricky but u can do it
Re: DIY: 05 Headlight Conversion to Fit 03-04
If you have HID's in your 2003's will they swap right over to the 2005's?
Yes, shouldnt be a problem. if it doesnt work then you have to switch the wiring like on the picture above. Good luck! :3_winkthu
Re: DIY: F/L Headlight Conversion to Fit 2003-2004 Models
awesome thats nice ...good work
Searched but cannot find the answer I am looking for. I am assuming the other connectors to the headlight remain the same. If I have HIDs for my low beams I do not need to splice wires or buy the harness correct?
I need help! how in the world do you pull the harness out in the 4th picture?! Its stuck for me :/
Can you just pull the entire 03-04 harness out and put it in an 05-06 without splicing. I have all of the wires out of my 04 headlights without having to cut anything which is why I am wondering
The grammar is awful in this, anyone have a better DIY? Its a litlte confusing.
Any help with this? This DIY is NOT clear. I need help!! Its too confusing!
Anyone? These directions don't make sense!! Can anyone explain more clearly???
can you pull out the wire harnes ? because my headlight has 6 plugs and the new one 4.
This DIY seems pretty easy enough, just to understand it, this is so that the stock oem power cord can connect to the aftermarket headlight harness right? :3_nosthum
1 - 20 of 53 Posts
