1 - 20 of 24 Posts
Ok, first off, let me start off by saying that I do realize this might be a stupid question, but I am genuinely confused.
I own a 2005 Tiburon.
According to google and wikipedia, all SE models come with V6 engines. My car has an SE badge on the rear bumper, so I (perhaps wrongly) assumed that it was an SE model.
The screenshot below is from Wikipedia..
135872
And this is from Google...
135871
I have done numerous different VIN searches online, and whats confusing is that my car is sometimes coming back as a V6/SE model and other times it's saying that its a 2.0L L4 DOHC 16V.
Here are some screenshots of the results coming back from various different VIN search websites.
The carfax (below) is coming back as an SE model, but with a 2.0 litre engine. (I was under the impression that all SE models were 2.7 litre)
135878
According to Hyundai, the VIN comes back as an SE as well...
135880
Hyundai Canadas site comes back as a "Tiburon Urban Edition" whatever the hell that means...
135879
And finally, yet another VIN checking app is saying my car is a V6 with a 2.7L engine...
135881
So, in conclusion, if someone can please clear this up for me, and let me know exactly how I would know for sure, that would be GREATLY appreciated.
Do you have a v6? If so, is it a manual 6 speed? If so, its definitely an SE. If you arent sure, take a picture of your engine bay and shifter.
Thats the issue. I don't know what type of engine it is. The engine cover says DOHC 16V, I believe. It's an automatic, with shiftronic. So that means it's not a V6, even though according to everything Ive read, they didn't make none V6 versions of the SE??
Post a picture of your engine bay. Or if you're impatient, take off the top engine cover. A v6 will have six"pipes" visible on the upper intake manifold (the big aluminum thing right in the top center)
DOHC 16V is the 4 cylinder engine
16V = 16 Valves
DOHC = Dual Over Head Cams
2 Cams x 2 Ports (intake + exhaust) x 4 cyl = 16 Valves
Yep, Omar is correct!. I dont believe its an SE. However, a simple call to the dealer will tell you everything you need to know. They will ask you for your vin number, and they will tell you for sure everything you would want to know and more.
16v is definitely a 4-cylinder. However, I see you're in Canada and I'm pretty sure the trim levels didn't follow the US norms. Yes in the US all SEs were V6 and 6-speed, but not necessarily in Canada. For example, Canada also had a Tuscani edition, which the US never had.
Discussion Starter #10
Yes, I am in Canada.
Here is the photo of the engine cover.
135884
I guess VIN numbers coming back as different models is a more common thing than I had originally thought?
Though photo #2 that I posted is directly from Hyundais website and my vin came back as an SE....Still kinda confused here.
Yep, this is an inline 4.
P.S. you might want to top off your power steering fluid a bit, it is almost at the 'min' mark.
Yeah, sometimes websites are not accurate. I would call your local dealer directly because they would have the correct information in order to be able to provide correct parts for your car. Talk to the parts department.
does the engine vin match the vin thats on the dash/ door jam?
Theres a ! in the vin :p
Edit: I was doing some reading on the wiki. In the UK they offered a 2.0SE model. It didnt say much about canada, but its possible that the UK and Canada share similar trim packages
So no one knows if they offered a 2.0 se model in canada?
Like three people have told you "yes" or "probably". What are you still confused about? Everyone has given you good advice except the second or so reply that said to take your engine apart some to look for six runners. It is easy to tell if it is 4 or 6 cyl with NO touching. Why do you care so much if it is an SE or not? It is a 4 cyl automatic. That sucks. Doesn't matter if it is SE or not.
easy bro. she was wondering if there was an SE trim with 4cyl in Canada.
where is the confusion here?
A pop-off cosmetic cover isn't exactly "taking an engine apart", and I know if I was op I'd want firm, definite proof either way. It's unlikely but engines can be swapped.
And honestly if I thought I bought a v6 to later discover it was a 4cyl, I'd be kinda pissed. Op has legitimate cause to care about this and if you don't then just stop reading.
1 - 20 of 24 Posts
