Is that component replaceable or will I need to remove and replace the whole motor? Where is the motor located? Where is the resistor located?probably the blower motor resistor
Negative, warranty is expired. Sorry for not having my signature filled out. The car is 2003 GT with the manual climate control system.Are you still under warrenty?
Thanks for the suggestion, I'll do that. I also noticed that if I put in on the #3 or #4 settings, and push the knob inwards, the fan comes on at that speed. What's up with that?I had a problem like this and pulled the middle panel off and looked behind it and saw that some of the wires were touching... I bent them in a way that they weren't touching and it worked again... try that before you spend any $$
You were right...the switch was definitely melting. Part is on order.Your fan switch is melting! Seriously, pull off the center dash panel and have a look. I'm on my 5th or 6th switch. The good news is that the switch is only abour $30 at the dealer.
