Is anyone has that combo installed on their Tib (GT 6 speeds)?
if so , did you have any isues / problem?
i do have that combo installed (less than 500 miles ago) and experience some unusual chatter only at start on first gear, like it is grabbing inconsistantly the flywheel steel band. no issue on any other gear ratio shifting...
is anyone experienced that?
also did you modify or not you clutch actuator by removing that fluid restrictor or not?
Thank for your feed back.....
Nick
chatter is normal....if you search, you will find another thread on this also
I have the same exact setup and when I have the car sitting like at a drive-thru,,,I have it in neutral and my brake on, I hear the same chatter. No I haven't done the slave cylinder mod,,,,,,I gotta wait til I can get my husband to undo the bolt,,,it's a little bit tough.
I have similiar setup just installed last week by hyundai themselves, except i put in the 400 clutch and i have that restrictor fluid mod done, no chatter here, but my hat what a difference! Every tib should have this clutch combo setup....
